How are you mounting the morel tempo ultra tweeters? There are no mounting tabs. Just to be sure, you said we should use the morel crossover also correct?Crutchfield is wrong. Critchfields “compatibility checker” is not very accurate in the majority of cases. It’s a 25mm tweeter. That’s the same size tweeter as the stock tweeter. Source, I and hundreds of other people have fit them in the stock locations with zero modification.
