How To DIY Painted Edges on Taillights
MrGreen33
Rancho Cucamonga, CA USA
Before DIY:
After DIY:
What is needed:
1.) 8mm or 5/16th socket or wrench
2.) Black paint
3.) Tiny brush
4.) Needle and a syringe
5.) WD-40
6.) Rags
7.) Razorblade
*Overspill or having the paint on a surface not intended on the truck or light, do to operator error, can normally be removed with a small touch up of the almighty, WD-40.
Step 1
Remove Taillights
1. Open Tailgate.
2. Each Taillight has Two 8mm (or 5/16) screws, that needs to be removed.
3. Pull tail light out.
4. Disconnect the taillight.
Step 2
Pre-Paint Prep work
1. Clean tail lights with water and a cloth.
2. Inspect the inside edge of the taillight and look for excess glue that can impede the paint from bonding with the desired location.
With a Razorblade, remove the excess glue from the inside edge of the taillight.
4. If needed, repeat step 1 after completing step 2, if excess glue was removed.
Step 3
Paint
Paint type: I Testors gloss black model enamel paint. Although a good Idea might be to use/try the FORD OEM touch up paint available at the local FORD dealer.
1. Use a tiny brush, with stiff bristles, to paint the inside of the taillights edge.
(Rumor is that a syringe works best…problem is I am not sure how to get one…hehe)
2. Let the paint dry for a few hours, and repeat step one until to apply a second or third coat.
3. Let paint dry after the last coat…I left mine drying overnight.
blockdoc
Lexington, KY
I like the idea of using touch up paint. Either from Ford or somebody like NAPA.
I think a syringe would be more difficult to apply evenly than a brush. Many children's OTC medications come with a non-sterile syringe. I'd think a pharmacy might have some for sale for that sort of purpose.
verytalonted
San Angelo, TX
Can anyone provide more pics of the process???
This 'mod' is something I would like to do but am still unsure of where the paint would be going (the syringe part confuses me?)
MrGreen33
MrGreen33
Disclaimer...these are not my photos.
Have not taken my tails off again...but I found these photos which show where to paint the back side of the taillight edge.
