DIY Maintenance Thread
Wilson
South Dakota
I would also recommend knowing the coast of your dealer doing an oil change for you at WatertownFordChrysler labor is under $10 and thy check every thing out for you so at that price I bring it to them.
nold
Dallas
when you put an oil on the new oil filter its messy, is it ok not to put an oil on the oil filter?
Nick@Apollo-Optics
It helps it get a better seal. Whenever I change oil, I always wear either latex or rubber gloves. Once you have the oil drained and the old filter out just dip your gloved finger into some of the old oil and rub it around the rubber seal on the new filter. This ensures a tight seal with no leaks. And it's not messy at all.
nold
Dallas
sorry i meant filling the new oil filter with oil as opposed to dabbing oil onto it.
Wilson
South Dakota
just enuff to wet the paper is good it don't need to be full or so full it runs down your leg altho it'd make her happy
Humvee21
Humvee21
You can get it about 1/4 full without making a mess when installing it. Put as much as you can, but do not exceed 1/2 way. Good luck
Vash
OK, USA
Might seem obvious and common sense, but make sure you check the new filter for leaks with the engine running prior to reinstalling the skid plate or access panel.
Humvee21
Humvee21
I will post a video later on how to replenish the windshield washer fluid.
Saints, did you ever get to doing this?
Hoping to get something going on this thread... It would be helpful for a lot of us.
