04Ram2500Hemi
It's Just a Username
So I'm having an internal battle with the 12 year old in me, and I'm 50/50 on Ditch Lights. If you have them, can you post some pictures for me?
By ditch lights, assuming you're referring to lights mounted on the a-pillars. Because the lights mount physically higher on the truck, it's a great location to install a set of spot lights. The extra height helps carry the light further down range. Our most popular light setup is the Baja Designs XL80's. Another great option is the Rigid Side Shooters or the Baja Designs LP series with their side projecting LED's. The side projecting LED's helps to illuminate everything off of the driver and passenger side of the vehicle while the forward projecting LED's help throw light ahead.
We keep tons of options in stock and are happy to help!
Ph ---->>>> 888-466-8991
Web ---->>>> OFFROADALLIANCE.COM
Thank you for the response, and yes the A Pillars. I really don't want something huge like what you've included. I'm thinking something a little smaller, and definitely square.
Maybe something along these lines (brand can differ, just thinking size)
https://www.roughcountry.com/3-inch-led-wide-angle-lights-70904.html
What do you want the lights for?
aesthetics?
function
both
just because?
Other?
For function, I’d go big, XL80 works great here. I have them with spot lenses and run them with my S8, the output is impressive.
Aesthetics - Really the XL80 looks big in the pictures, and I won’t lie, it is a little big next to the squadrons, but they are a really good fit size wise for the truck.
Squadron sized or a light with some side shooting capability. LP4 ?
IMO a squadron class light is underpowered for this use case. Use the height to get some distance lighting.
hang some S1’s at an angle to light up beside the truck for bonus points.
I would not try to get “in fill” lighting with wide angle lenses here, you’ll get some significant hood splash and lose quite a bit due to positioning.
You can do anything from tiny Baja Designs S1s up to the big Baja Designs XL80, which seem to be the most popular amongst Raptor owners. You can also do Baja Designs LP4, LP6 and LP9 but those are REALLY big.
Here are some XL's mounted to some a-pillar mounts:
Here are some Squadrons mounted on the a-pillar. A little smaller
Now, depending on what your real use is, the lights can differ. We stock everything from the tiny Baja Designs S1 lights up to the big boys, the LP9 (although XL80 is where i'd stop).
Shoot me a message and we can help you choose the right lights. We stock everything you need from the brackets to the lights + wiring harnesses. Everything to make installation easy.
If you want a killer setup, the XL80 is a fan favorite and we have a kit on sale (through Wednesday) which includes EVERYTHING You need (brackets, lights, wiring harness):
Price starts at $789 once added to your cart (discount applied in your cart): http://www.4x4truckleds.com/baja-designs-ford-raptor-2017-xl80-a-pillar-lighting-kit/
