Questions:
* How does it mount and seal? Any holes need to be drilled?
* Tell me about the lights - colors, quantity of each, lumens, etc.
* Does it have the required marker lights?
* How are the lights selected/controlled?
* Can it be removed and the factory light re-installed?
It does require drilling on each side of the cab for installation and has a gasket to seal it to the truck.
The lights are 3 Baja Designs S2 Flush Mount lights. You can run run white, amber, red, blue, or green lenses. You can choose the S2 Sport or the S2 Pro.
It does NOT have the three DOT required lights, only two.
You’ll have to tap into the factory wiring for the cargo, running lamp, and brake lamps. The S2s will have to be wired into your upfitter switches or any other onboard switches you may have installed.
It can be removed. To go back to stock, you’d have to re-wire into the factory harness, which may not be an issue depending on how you wired the light. You would also have to patch the holes you drilled.
Hope that answers everything!
---------- Post added at 11:00 AM ---------- Previous post was at 10:59 AM ----------
Hi Nick,
What can we do about a group buy?
Let me talk to Doug and see what we can do.
