Fury Road
Worst option I've seen so far.
You think tailgate pad is a bad option?
Yes. The worst possible option available.You think tailgate pad is a bad option?
Agreed, too easy to steal a valuable bicycle, bounce the bike up and get the cover up above the front axle and get a tailgate scratched up.Yes. The worst possible option available.
What fork mounts are you using?
Yep if I take it anywhere it will be sitting like my office I’ll put it in the bed with an extra cable lock. Between that and the front being through axle bolted in it would take some time to steal it.Agreed, too easy to steal a valuable bicycle, bounce the bike up and get the cover up above the front axle and get a tailgate scratched up.
That's why I use the 1up and their security lock to block the tension screw.
I looked up the seasucker husky, don't see the one you used.I added fork mounts to the factory bed hooks so I can either flip up the cover or remove it and mount two bikes in the bed or I am carry them out back if needed depending on what’s going on.
E not y in huskeThis idea makes a lot of sense. I can easily remove the back section and mount the bike sideways without front wheel.
Yep that’s it. With my Mtn bike the front wheel fits between the rear wheel and the cleat on the opposite side so I strap them both to the cleat and run a cable lock through the anchor point that is low in the bed then trough the wheel and back of the frame.
Hmm. Now you have me looking at the 1 up [emoji30]I just usually tilt up my back seats and load my road bike in the backseat area. For travel when loaded up I use my 1up.
