Definitely needs to be leveled
dinoone
Hows that going to effect UCA and droop? When will they be on sale?
Digger
Digger
Oxford, Ma
---------- Post added at 09:57 AM ---------- Previous post was at 09:55 AM ----------
Measured a truck on the lot. From factory the front was 2-1/4" lower then the rear. Truck had 14 miles on it. This will do the trick.
I'm on your site and they aren't available yet. Do you know I'd be able to get a set? Thanks, Mike
RPG
Orange County
We are working on finishing them up then we will put them on the site. Still needs Anodizing and Laser etching
Send us an email at [email protected] and we will get you the list.
---------- Post added at 09:26 AM ---------- Previous post was at 09:24 AM ----------
Leave it to Corey @RPG he always has our backs. Merry Xmas buddy.
Thank you Sir and a very Merry Christmas to you also.
---------- Post added at 09:33 AM ---------- Previous post was at 09:26 AM ----------
We are simply adding more preload to the spring. Just like a perch mod on gen 1. No changes in travel or clearance issues. We should have this batch ready to ship out Jan 8. Still need anodizing and laser etching.
Robtor310
Redondo Beach CA
RPG, sent you an email for the waiting list.
Couple questions though.
Is an alignment reccomended? Does it change camber?
Is there a logical reason why Ford has the 2.25" variance from front to rear?
Thanks in advance.
SilentShooter
Siesta Key, FL
Thanks in advance.
I alignment is always recommended. And pretty sure ford has the front lower than they really would like to keep the Feds happy with bumper height for impacts and such and also take into account the rear is designed for a bed load so a couple hundred pounds in the bed and it drops. which is why most the run with racks and gear get HD/+ spring stacks
dude1782
PHX, AZ/SLO, CA
In another thread someone mentioned longer springs would also be an option. What would the major differences end up being between the RPG collar and longer springs? Would the suspension act differently?
---------- Post added at 12:42 AM ---------- Previous post was at 12:41 AM ----------
How much would springs cost vs the collar?
