Definitely needs to be leveled
BRAPPPP
San Luis Obispo, Ca
How do you not change geometry with the addition of a lift kit?
Drop brackets keeps the suspension at stock geometry while raising the truck. So the truck moves up but the moving parts stay put. Using a shock collar causes poor CV angles and pre loads the shock. Not optimal.
bstoner59
does it come in shmedium?
Orange, CA
What? This doesn't make sense. How is your CV angle not changing if you are moving the lower control arm and wheel down?
Maybe I'm missing something?
Pacific Wheel
Reno, NV
Since the Raptor is a mid/long travel truck from the factory you don't want to weaken the area where the LCA's bolt on(cross member). A bolt on cross member is just putting the truck on stilts essentially. Higher center of gravity and weaker cross member are not ideal for a spirited desert run. I'm sure the pros @svc or @RPG or @SDHQ or @Rogue Racing could probably elaborate more on why you don't lift a raptor. This is just my 2 cents.
2014RubyRed
Galesburg, IL
You could always just do a body lift, I guess. If lifted life is your thing, do it.
Preloading the springs is not a terrible thing or un-optimal. It's tested. It works......
crash457
I'm Batman
St. Louis, MO
kdub405
Are we really talking about body lifts on a raptor??
sea2jet
Bajamod has gone up $100 since they first announced their lift. Manufacturing cost must have been more than they expected.
BRAPPPP
San Luis Obispo, Ca
So you rather have a pre loaded shock with ****** CV angles than a drop bracket on your lower control arm that increases your center of gravity by uh 3 inches lol. You guys should actually look at how the trucks geometry is changing rather than just cringing when you hear body lift. That just means we are raising the truck a few inches to level it and maintaining stock geometry. You are trying to level by changing the geometry and putting your shock in a non optimal position.
