Deavers
Booth9999
Idyllwild
Ok so to be clear if I run the +3 with the rear shackles then I would be at the stock height? What would the net benefit be? More travel and less axle wrap? I'm totally stock currently but getting ready for adding the RPG rear bump kit and deavers. Any recommendations appreciated, I'm concerned with adding a front collar with the Torsten diff in front but am here for your infinite knowledge and recommendations. Thanks!
zombiekiller
OG BooBooRunner
New Orleans
I have the +3s , SDHQ 1" drop shackles and RPG 1.5" collars right now.
The truck sits "stinkbug" by a little over 1" with no load in the bed.
I have had the springs on my truck for about 2,000 miles.
I am waiting for my RPG adjustable collars to arrive. I'm thinking that 2.5" would be the sweet spot unloaded and 2" will be the sweet spot loaded with spares, bed rack, recovery tools, etc. with the stock front bumper and IC.
I'll be doing the ADD pro bumper after i get my full race intercooler. ( its about 3 weeks out.) Between the IC and bumper, I'll drop a few pounds, so perhaps the 2.0 will be where i finally sit while running 35s.
I'll be working with TMX in dallas to fine tune where the suspension needs to be when i go to 37s. If i need to ditch the drop shackles because the front needs more lift to clear 37s, I can simply switch to camburg tig shackles and move on with life.
Now, If i decide to, I can leave the drop shackles, go with an RST18, run bed through 4.0s in the back and add limit straps.
I went this route to have the most flexibility moving forward while dropping the least amount of coin to get it.
If i had to do it all over again, I would not have bought fixed collars.
iceman7273
Nor Cal
I have +3 deavers and 2.25 perch up front. I am higher in rear by 1/2" which is what i want with the bed empty.
mikepipe597
What is the distance from the top of your rear tire to the bottom of your fender? Your last pic looks taller then just one inch over stock? You did say you went with the stock +3 deaver and nothing else, correct?
iceman7273
Nor Cal
Last pic is the rear drooped out. Not ride height
Gsteve
amazing that ford has spent $$$$$$ on these trucks and still after so many years still put on shit springs. i hated my 14 til i changed em.
RWE
Burbank, Ca
when did you order your intercooler?
RWE
Burbank, Ca
Are deavers really a noticeable change on this truck? on the 14 I really didn't think they were worth it but everyone seems to be going crazy about them here.
zombiekiller
OG BooBooRunner
New Orleans
Black friday/cyber monday sale. I'm hoping that It arrives between xmas and new years so I can get it installed before I have to start traveling for work again.
HUGE difference in the truck's behavior. The rear end is less jittery and WAY more predictable both on road and off.
As an FYI, With +3 deavers, 1" sdhq drop shackles and the RPG adjustable collars set to 2.5", My truck is almost perfectly level with an unloaded bed.
I'm thinking 3" front and swapping the drop shackles for camburg TIG shackles will put me exactly where I want to be with a loaded bed and 37s.
