Deaver +2 or Deaver +3 with Shackle?
dewalt
Geisers and plus 4 deavers HD is a factory look. SVC bump stop with a 2.5 x 4 cylinder will let you load up
sixshooter_45
Arnold
I do not know . Never been empty.
Ok, thanks. Trying to decide between HD and regular springs.
Some say Geiser springs up front and Deaver's +3 and some say Deaver's +4 gives a stock look.
Eventually I want to set this up for overland camping and off roading with a few extra inches of lift.
coachhomer
Do the Fox 3.0 fronts come shipped at mid perch? I am level right now at mid perch and I am going to add the +3 Deavers in the back and the Fox 3.0s in the front. From what I am reading that will put me 1” higher in the back? If the 3.0s come mid perch.
Anyone? Bueler?
dewalt
Plus 4's lift the back 2 inches. Geisers lift the front about the same. The hds are the way to go if using the bed for anything more than a suitcase. With the bump stops you can vary nitrogen to give you whatever load capacity you need. You can get a 2 or 4 inch stroke bump stop. If you had a pair of 2 and a pair of 4 you can do anything.I think you can get 11,12,13 leafs depending on application
Badgertits
Ma
Do you need to add bump stops period when swapping leafs even these HD/+4s?
I mean I’ve seen bump stops that are simply hard rubber on a metal block & ive seen em be essentially a shock itself w/ nitrogen or hydraulic fluid whatever- is there a cheap option?
