Damn Weasels.
t_j
Chicago, IL
Don't we have 2 plugs per cylinder? Could it be that there was no code because 1 spark was enough to keep all the readings in range? Now if it was both plugs on 1 I would expect a code.
Sent from my SM-T520 using Tapatalk
Rookie
Fort Wayne, IN
you are hereby banned from doing anymore wiring in your truck until i can teach you the proper techniques
Mine looked like that when I installed the bumper and 10 d2s. Didn't have time to make it pretty. I also cut corners and used a scotchlock to connect the pass thru wire and it couldn't handle the load. Had to solder it when we stopped on the trail.
