Curved Light Bar Behind Grille
S
Sinraptor
Greer, South Carolina
Also if I got with 40 inch light bar which upfitter switch is best? I know the first 2 are 30 amps, 3 is 15 amps and 4 is 10 amps. It's a 240w. So can I put it on number 2 and leave number 1 for my 50 inch?
The Macf
Vegas
I think that is the route im going first. I have halo headlights and i think this 40 inch will go well with it for the use im going to be going with it. I know rigid sells the brackets and wiring harness for this for like 34.99, is that all i would need? Thanks for everyone's help
Thats what i am thinking. 40 inch behind the grille, then later a 20 inch amber light in lower grille, 4 dually fog lights then 50 inch above windshield
You should buy my old mounting brackets. And no you can never have enough lights.
cwickd
Asheville, NC.
Does anyone know if any amber fog lights are available for the factory bumper fog light openings? I want to run ambers in my fog light openings and a 20"- 40" bar before the bumper in the middle. I'm looking at pricing and am surprised how expensive some of these light kits are.
Nick@Apollo-Optics
We offer our Apollo4 in a true amber version. You can check it out on our website here: Apollo4 | Apollo Optics, Inc. | Premium LED Off-Road Lighting
It's a perfect fit in our lower bumper openings and we can put together a package deal for you including the mounts. Let me know if you would like some more information.
cwickd
Asheville, NC.
Hi nick,
If these are cubes and can fit 2 each side, I would like to order 2 for each side and a 30 " bar for the middle . I went to the website and it said they were unavailable. Can you work me up an estimate?
Nick@Apollo-Optics
Hi nick,
@cwickd - I've got a PM coming your way shortly.
As for the website, if you selected spot for amber or anything other than the 3 Watt version, it can cause it so unavailable.
And yes, you can fit two per side. I have two Apollo4 white spots and two Apollo4 amber floods installed in the lower bumper openings of my personal truck.
S
Sinraptor
I went ahead and pulled the trigger and got a straight 40 inch led light bar and Rigid upper grille mounts/wiring. I just decided to do a straight behind the grille since im looking light as it is and then i will do a curved 50 inch above windshield later. I CANT WAIT to install
Ni9mm
Florida
If that setup doesn't work for you,
We carry an OnX6 LED Light Bar Raptor Kit (40")
OnX6, LED Light Bar Raptor Kit (40")
Now you can easily mount the same light used by top race teams and keep it hidden cleanly behind the grill of your Ford Raptor. The new OnX6 LED Light Bar is the only light bar on the market that has the distance of an 8” HID with the smooth spread of an LED
Includes everything needed to mount and hook up the light bar.
- 40" OnX6 LED Light Bar
- Ford Upfitter Wiring Harness OnX6
- OEM Raptor BTG Bracket Set
Let me know if you have any questions!
Thank You,
Bailey, Baja Designs
I got questions. Do you have a roof mount kit ? If so can you get me pics ? Are there any plans to make a 54 onx6 arc ?
@RangerRob maybe you could answer those questions. Definitely looks like a 60 in your photo but I don't see anything like that on BD's website. You got some splainin to do.
Baja Designs
We do not have a roof mount kit for the raptor.
Currently we do have a 50" OnX6 light bar. Some customers have custom requested a 60". It is something we have made custom in the past.
Thanks,
Bailey
RangerRob
Ramona, CA
BD makes the OnX6 in 10 inch sections. The 60" is not on their site. I got with Christian from BD to custom order the 60". I'm sure Bailey could help you just the same. It took BD about 3 weeks to build my light and I'm extremely happy with it. Best lights on the market!
My mounts are custom build as well, by an employee at Raceco.
-Rob
