Curved 20" LED bumper light install
menerso
2019 Raptor SCREW
Maple Grove, MN
I looked all over to see if anyone had a curved 20 inch light in the front bumper. I didn't find any pictures so I figured I would show you what it looks like. I don't need to go through the install since there are several other threads for that.
Looks good. Pain in ass getting the side screws tight, but I got it down.
Also, lowered my license plate too.
menerso
menerso
2019 Raptor SCREW
Maple Grove, MN
raptrcrzy
Camarors64
How did you mount your license plate? How is the output of your bar?
It looks like you used the rigid mounting bracket, did you just follow rigids instructions?
menerso
menerso
2019 Raptor SCREW
Maple Grove, MN
I did use the Rigid mount. I went by their instructuctions other than i drilled holes @ 2" from the edges (there was a lot of room)
As for the plate, I drilled new holes in the bottom part of the bumper and put threaded inserts in. The plastic factory plate mount fit perfect and the hooks on the back of the mount are pressed up against the bumper so that it supports it too.
Output is really good. I have a 30" that is on order and I am putting that one behind the grill. The combined output will be more than enough... but I say that now.
marty
