CrystaLux LED License Plate Kits from 4x4TruckLEDs.com
4x4TruckLEDs.com
We're now taking pre-orders for our new CrystaLux LED License Plate Kits.
This kit includes 2 new license plate assemblies with integrated LED chips.
A high quality T10 connector comes pre-installed ensuring a solid connection.
Installation is simple and only takes a few seconds.
1) Reach under your rear bumper and push the tab on your existing assembly popping it out of the bumper
2) Twist the factory connector from the assembly and remove the old halogen bulb
3) Plug in your new CrystaLux LED License Plate assembly into the factory connector
4) Push the wires into the new assembly and twist the factory connector onto the assembly
5) Re-install the assembly into the bumper ensuring both sides snap into place
Now sit back and enjoy your new CrystaLux LED License Plate assemblies.
Compatible with the following vehicles:
  • 2015+ Ford F-150
  • 2017+ Ford F-150 Raptor
These are expected to us sometime in July so we're taking pre-orders on them now. They are $50 a pair but if you use coupon code RAPTORFORUM you'll save 10%
While not as cheap as a pair of $16 LED bulbs, the design is rock solid and really slick looking. Well worth the upgrade.
Available here: http://www.4x4truckleds.com/crystalux-led-license-plate-kit-for-2015-ford-f-150/
4x4TruckLEDs.com
4x4TruckLEDs.com
Damn kinda put this on hold for a bit. Let me check the ones on my truck and see how they are holding up. I've been the main guinea pig as well as some others.
Sidewayz
Austin
Sounds good, just let me know if you decide to stock again cause I will probably grab a pair from you..
