CRP stage 4 build (lower than expected power levels)
G
Guy
Dillard,
This was Lars truck from Gearhead on 93, similar turbos. He hit the same wall. They have the upper RPM range cleaner than mine but it’s the same plot basically.
so I don’t know if there is any more torque to be had.
dillard09
College Station, TX and Socal
Dillard,
But was that torque curve at 500 max because of a stock motor? I guess I'm going to find out.
G
Guy
Not sure if Lars had manifolds or what other bolts on he did. Probably typical bolt ons is my guess but probably not manifolds. I don’t think he held back... he just was limited by knock.
maybe the heads pick you up a little something. Not sure if the flow will matter
With the knock.
nikhsub1
Los Angeles
Guy - did you happed to dyno the truck on the same dyno BEFORE the mods? Dyno numbers are different so if you went to a different dyno, you are going to get different numbers. Maybe this dyno just is just very ungenerous? Dunno, just a thought because I usually laugh at folks who try to compare dyno sheets done on totally different dynos.
G
Guy
Yes.
baseline 367. 447 tuned. 411 stock tune with all bolts ons and turbos. 507 finished product and again all that power comes in the last 1200 RPM
G
Guy
Nope. 35s. Toyos. Not significantly different though.... even the shop said it’s not the tires.... no way you’re making up the difference for the inflated numbers.
4K rollers too so it has proper loading on the dyno jet.
it is what it is. I’m not saying it won’t take a tuned raptor in a straight line dig... it will... but it will not touch a TRX... and for that I’ll need another solution.
