CRP Manifolds with Garrett Power Max Turbos
thatJeepguy
GA
If
I continue to hear that cylinder pressure is a huge issue with these motors and keeping it in check is key to engine longevity. Changing out the manifolds is a way to alleviate that.
If the ports / valves are the same size how is changing out manifold going to make a diff?
J
JCT
Vermont
If
Every little bit helps.
I haven’t seen data on the 2nd Gen CRP manifolds, but CRP bench tested the 1st gen 3.5 manifolds, and showed that there was restriction in the stock manifolds, particularly for the front two cylinders. Head Games and Full Race did some testing on the stock 2nd Gen heads and a Full Race manifold design, and the aftermarket manifolds did flow better than stock heads with stock manifolds.
From a practical perspective I figure that if I am going to replace the turbos, I might as well do the manifolds as well. Probably not worth a ton of incremental power, but I bet they do make some difference from both a power and longevity perspective.
Zeusmotorworks
Might also make "cleaner" power. All too often you see shops results under best case scenario vs. what the set up is capible of on any given day. The latter was what I always tried to steer my customers towards when I was in the business. Generally those were the happier customers.
J
JCT
Vermont
I’m all about trying to avoid throwing a rod through the side of the block for as long as possible.
ruey220
Verdi, Nv
I thought the manifolds would allow better flow to the turbos to spool up quicker and less lag. knowing this alleviates cylinder pressure is even better. It worries me sometimes the increased boost i'm running is putting more additional pressure inside the motor.
Kmorgs
Florida
How much boost are you guys running on these larger turbos? My E50 tune is running 20psi, with upgraded turbos still at same PSI theoretically will make more power as it will be more efficient than the stock ones.
J
JCT
Vermont
I believe
I think Graybeard was running 22psi on 91 octane and somewhere in the high 20's on E85
