Crown Offroad's New Aux Switch Panel
CrownOffroad
CrownOffroad
San Diego, CA
Crown Offroad's newest switch panel has arrived! These panels are designed to accommodate the larger style rocker switches commonly called contura style rocker switches. Each plate is CAD designed, laser cut and built to hold a total of six contura rocker switches. The panel itself is 9.375" in width and 1.95" in height. These will be offered as a stand alone plate for you to add your choice of switches or complete with six contura single blue or red LED rocker switches. Each switch plate comes with black phosphate or stainless steel mounting hardware and shipping is included to the continental US. International shipments are available. PM or email us for international shipping quotes.
Link: Switches & Panels | Crown Offroad
CrownOffroad
CrownOffroad
San Diego, CA
The latest switch panel designed exclusively for the Ford F150 and Raptor is finally here! On the newer model trucks, Ford was nice enough to give us a small cubby hole in the dash which most have found to not be very useful. This panel is laser cut 5052 aluminum and fits perfectly. It attaches using heavy duty double sided tape for ease of installation as well as removal should you decide to take it out. Wiring the dual switches is equally as easy. Simply lower the glove box all the way down and drill a small hole into the black plastic compartment from the inside of the dash. Listed for $29.95, you get the switch panel, two contura style rocker switches and FREE shipping.
Deleted member 12951
Guest
Damn it Chris, why do you keep making cool shit. Looks like you can almost put 3 switches there by putting them just a little closer?
CrownOffroad
CrownOffroad
San Diego, CA
In the R&D phase, three was attempted. Because of the design of the plastic cubby itself and the desire to offer a panel that requires almost no modifications for installation, two was it.
AbnMP13
Mississippi
Someone who has installed this: the bottom connector is marked 12v, the other two aren't marked except for "1" and "2". Which is ground and which is the accessory? Directions mention nothing about the connections.
2014 Terrain SuperCrew
Vortex Mud Guards ~ Husky Floor Liners ~ Rigid Dually Flushmounts ~ Rigid Dually Clear & Amber Pods ~ Recon Smoked Mirror Lights ~ Bakflip FiberMax & BakBox ~ SVC Tune ~ Rigid 20" E2 Series - Combo ~ Mid Perch ~ Underhood & Bedlights ~ Rigid 40" Combo ~ ADD Stealth ~ Retrofit Headlights
