Created Custom Wiring Harness for Upfitter Switches
DINOZR
DINOZR
Southeast
anyhow. nice attention to detail, there's some good ingenuity going on there despite me thinking it is 100% not necessary. good for you.
Thanks! I enjoy not just doing the minimum necessary but doing my wiring well.
OICNW-Rob
Bend, Oregon
That is a really nice DIY harness! I searched the connector type, and the retailer I found the 12 way connector on states its only rated at 13 amps per contact. Upfitter switches 1&2 are rated for 15 amps. None of my lights are above 13 amps, but its something to consider.
wheelman55
Big Bend or MN
If you need more amps, you can connect from Deutsch unit to a relay. Then the deutsch pin will only see small amperage, as that wire will serve only to power the switch of the relay. Remember to use a fuse from power to relay to protect the wiring.
The aux and pass through wires are tiny. For higher amp use I would use a relay.
Aux wire sizes on my 2018 Raptor
2018 Colors with amp rating and wire gauge
Aux 1 - Green/White - 15A, 20 awg
Aux 2 - Brown/Blue - 15A, 20 awg
Aux 3 - Gray/Yellow - 10A, 20 awg
Aux 4 - Green/Yellow - 10A, 20 awg
Aux 5 - Brown/White - 5A, 22/24 awg
Aux 6 - Green/Orange - 5A, 22/24 awg
