Coolant question
Jwod1993
Collegeville, PA
Hi all -
Last weekend I was at a raptor event here in the northeast. It was at an off-road park where they set up a small 2mi course with a small jump.
On my second time out, a coolant hose popped off when going over the jump and dumped close to 3/4 of coolant out of my truck. Truck got hot and went into limp mode and I limped back to the pits to asses the issue. CEL came on and coolant temps got up to 265°. I’m not sure if ford missed a hose clamp from the factory or what because I’ve never heard of something like this happening to anyone. My truck is a 2023 with 10k miles on it and this was my first time offroad.
Luckily, someone else there had a spare hose clamp and I was able to refill with coolant, although motorcraft was not available. I plan to have the coolant system flushed next time I take it in for service.
I guess my question is - is my engine ok? I was able to get all of the air bubbles out of the system, and the truck runs fine right now. I’m just wondering if because I drove about 2mi (very slowly) back to a safe area with hardly any coolant in the truck if there may be any internal damage. Thanks for the feedback engine gurus.
Evasive
FL
So many questions. But I’ll just ask one. Doubt a clamp was missed. The jumping….that might be the cause….maybe…..
What coolant did you use?
greatone99
ma
might want to change the oil as well ,265 is pretty hot, but I doubt any damage, truck pro runs between 180 and 220, so I can't imagine 40 degrees for an extra 2 min did much.
thatJeepguy
GA
What were the oil temps? Dont forget the turbos are water cooled as well. And might have lost cooling for some time.
RdR2027
If it was my truck, I would take it in and get the coolant flushed and the oil changed along with having the service dept. check it out.
