Converted from Ram owner
Skyfrog
Brandon, FL
Welcome to the FRF!!!
Yes, definitely check out the vendors. They will have the best prices you can find. Just let them know you are from the FRF.
Also do some searches on the forum for comparisons of various products, like fog lights. Then you can decide on X versus Y brands.
Welcome to FRF.
For fogs, you can either make a bracket or buy one in a kit. The Baja Design lights have huge range, but that kind of range isn’t really necessary in the Mid Atlantic. Still great lights though.
and remember.
#BlackRaptorsMatter
Ditchplains1
Trescott, ME
BetaHauler,
Welcome!
Prior to my return to Ford and my Raptor I had two Dodge Cummins pickups. Spun the unit bearings in both trucks as well as the 5th gear in the NV 4500 tranny in the 98.5. The 2004.5 was a huge step forward in terms of comfort and room. I pulled an Econoline 25 foot tri axle tilt 9 ton goose neck trailer with both trucks...mileage towing? 18 mpg!
The smile from the Raptor is still here 4 years later....
Use the search prompt in the red bar on top to search the forum. Morrie at The Tonneau Factory Outlet...https://www.tonneaufactoryoutlet.com/ will help you with tonneau's, bed rugs etc. Make sure you mention being a member of the FordRaptorForum for a significant discount...Many of the supporting vendors do the same...
Good luck!
Eddie
