Constant Trailer connected/disconnected alerts
rabidranger
Michigan
A few minutes after my truck (2018 SCAB) is warmed up and I accelerate from a stop a get a "Trailer Connected" Alert on the dash. When I brake I get the "Trailer Disconnected" alert. Back and forth. Da-ding, da-ding, da-ding. Makes me want to jerk the wheel into oncoming traffic. Seems worse when the temp is above freezing. Sometimes a "Trailer right turn lamps fault, check lamps" alert pops up. Same alert for left lamps too, usually one after the other. Sometimes the trailer blind spot fault pops up too, but I forget the actual alert phrasing. I checked the plug in the bumper and even cleaned it out with some good contact cleaner. Still does it. Unplugged the harness from the bumper connector and taped it off. Still does it. THose 2 connections look good and brand new, no signs of corrosion. Not sure where to check next. I know there is a TSB for this, but dealer wants $200 to diagnose and my truck is out of warranty. Any advice?
pastorwug
Santa Maria, CA
Mine does the same, but only when my trailer is actually connected. It goes back and forth with connection and disconnected. Drives me nuts, I believe there is a TSB for this, I'm going to try to find that.
rabidranger
rabidranger
Michigan
It seems insane to me that Ford though it would be a good idea to have those alerts cycle and distract the driver constantly. Just alert once for each per key cycle.
trailer diaconnected is usually a brake wire. thats how the truck determines a trailer is connected (gen 1 at least) check the wire harness on the trailer all the way back to the tail lights. might be a pinched or broken wire. after that, then definitely have the truck checked out.
pastorwug
Santa Maria, CA
I have a 2020 Caravel Airstream, but even new RVs can have electrical issues. I've been thinking of changing out the 7 prong female connector on the trailer - start there and then go deeper.
rabidranger
rabidranger
Michigan
Just to be clear, I have no trailer hooked up while it does this. I even unplugged the harness from the connector in the bumper and sealed it up. Going to get under it this weekend and check all the connectors and grounds.
rabidranger
rabidranger
Michigan
Have a copy of that TSB, or know what number it is? Went by the dealer and they couldn't find one.
18-2106. It's a crap TSB, because even with the connector unplugged as per the TSB instructions, it still does it. So there has to be damage, corrosion or a bad ground somewhere upstream in the harness.
all the info prior to asking is helpful.......
