Connecting GJ Motorsport 3rd brake light
roscopeeco78
Do I need to connect the existing harness to the GJ light. If so I have no clue where to connect. Please view pictures to see what I am talking about.
2013 raptor.
thanks for the help
roscopeeco78
roscopeeco78
disregard the above post I figured it out...If someone could take a look at the long post below this post and help that would be great.
roscopeeco78
roscopeeco78
Having a small problem and if anyone can help let me know...
Update. I went ahead and tapped into the blue and white wire. I have the ambers working fun off the six switch 4. I have not been able to get the clear Baja light to come on. They only thing that I left unplug was the existing harness to OEM third brake light. I was assuming I did not need that due to tapping the white GJ wire into the (blue and white) wire as written in the instructions.
I cannot find where I connect the Grey piece from the GJ harness. It is in the first picture.
the second picture is of what I unplugged from the OEM brake light. It has three pins and I was thinking that just stays unconnected.
so the two pictures are the only two that I cannot find anything to connect them.
b7a28f21-9651-4cbc-8a36-c28491e22830-jpeg.146682
8d802b90-180d-4f3e-ab8d-665f8790190b-jpeg.146683
renegadeagle
Puerto Rico
Very good afternoon
I don't know if you solved your challenge but...
The gray connector from the New GJ Harness goes inside the headliner substituting the original harness connector
You have to follow the original harness back unplug it and connect the GJ Gray connector.
You completely eliminate the original harness
Best regards and respects
