Jhollowell
Hey guys i had a question for those of you that swapped out coil springs and did it yourself. After installing the top hat is it still possible to rotate it independently from rotating the spring? I’m about to do it myself and realized that you need to make sure the 3 studs in the hat line up with the 3 holes in the bucket but also need to have the lower bolt line up with the LCA. Once the perch is on the spring can’t rotate so I’m wondering if it’s still possible to rotate the hat without rotating the spring. Hope that made sense
