COBB Tuning TCM Support Has Been Released!
Nick@Apollo-Optics
Nick@Apollo-Optics
What's the procedure for adding the TCM flash when you've already done the ECM flash. Do you have to uninstall and start over or do you just hook it up and tell it to do the TCM flash. I'm sure I can ask Cobb this question, but how do you add the maps to the AccessPort once you buy from Cobb?
You can purchase the TCM Unlock from COBB or any other authorized dealer, like us.
Once you receive the TCM Unlock Key via email, you hook up your Accessport manager, enter the unlock key, and then update your firmware.
Then, you'll hook your device back up to your truck.
If you're not running the most update ECU tune, I'd flash the most recent file. If you are running the most recent ECU file, leave it as is. The important thing is to just make sure that a COBB ECU file is loaded.
Once you've confirmed and ECU file is loaded, load the TCM file of your choice.
DeaThomas
Huntsville AL
I was running COBB engine tune without TCM. I'm considering purchasing TCM tune but concerned about using adaptive cruise control. Waiting to hear back from them about that before I purchase.
Mbdurham
Georgia
I have had no issues with ACC since installing the TCM tune
DeaThomas
Huntsville AL
Thanks for the reply. I have 2019. The map was based on 2019 OEM tune. Does COBB TCM tune improve 2019 Raptor enough to make worthwhile purchase?
Mbdurham
Georgia
Oh yea definitely mines a 19 as well. I still haven’t tried the sport tune as the OEM+ is perfect to me. If I want sportier I switch to sport mode.
DeaThomas
Huntsville AL
Ok- I loaded the TCM OEM+. I like it a lot so far. Much smoother and downshift is right on. I haven’t tried cruise control or Sport yet. Will post results when I do. Also if you update make sure you don’t have “beta” checked in advanced section of you accessport manager program. It won’t load to your truck if you do.
