COBB Tuning TCM Support Has Been Released!
Mbdurham
Georgia
You'll enjoy it. Initial feedback has been all-around positive for clients running both the OEM+ and Sport TCM maps. Most are running the Sport map, no surprise there. We are all a bunch of Raptor owners after all haha
Nick
Same here. Really enjoying OEM+ with stage 2 93 OTS tune. Shifting is much better. Going to try Sport this afternoon
P4mnceBlue82
West Virginia
I'm enjoying the tcm tune as well. OEM+ is great. Very smooth. A slight slip/hesitation from 3rd-4th when in sport mode BUT overall VERY big improvement.
Now, the Sport tcm tune is a diff story for me. I ran it for about 3 days and the 3rd-4th shift that has a very slight slip/hesitation in OEM+ is even more apparent with Sport tcm tune and in sport mode. It's very consistent. But diff depending on throttle position. With slight throttle it's ok and reasonably smooth but with quarter to half it will kinda rev-hesitate-and slam into gear going from 3-4. That's the ONLY shift that does that. Every other shift is smooth as butter. Now if I flog it, it goes thru em so fast it just feels like really firm shifts until 6 then starting holding gears a bit longer and smooths out.
Anyone else experience this 3-4 shift issue or just me?
Antho
Was an issue with me on factory trans tune. Only did it in sport mode. I’ve since figured out it only does it in sport when the trans is cold. I won’t put it into sport until after the trans is atleast at 110 degrees. Then shifts awesome in sport. I would assume it’s the same with the tune. Should try it and see.
NHDude4
Southwest, NH
What's the procedure for adding the TCM flash when you've already done the ECM flash. Do you have to uninstall and start over or do you just hook it up and tell it to do the TCM flash. I'm sure I can ask Cobb this question, but how do you add the maps to the AccessPort once you buy from Cobb?
