GEN 2 COBB Accessport - Tuned by GooseTuned
BIGDJE
OC, CALI
You wouldn't happen to be in Orange County CA would you? Apparently the fuel isn't any good around here! My tune doesn't seem to like the 91 fuel, If anyone can point me in the right direction it would be much appreciated. Thanks.
I live in orange county you need @wgr73 make you a E50 tune thats what i have 500hp to rear i go to ExxonMobil has E85 i do 16 gallons E85 rest 91 blends to E50 and runs like a beast
Sent from my SM-G975U using Tapatalk
dixonk
HMFIC
Oklahoma
I am in Oklahoma. Some bad news, just came back from being out of town and the Shell station switched everything above 87 to non ethanol as well. I now have no place for buying 91 with ethanol.
GooseTuned
GooseTuned
New Mexico
That sucks. If all you have is 91 go with that. Ethanol enriched fuel really helps combat detonation. If you have ethanol close by throw a couple gallons in, wont hurt the tune and will only help with detonation resistance
NeverEnoughHP
I'm running into the same issue with a bit of detination in the recently higher temps reaching up into the mid 90's. So you're saying to add a few gallons of e85 to top off a tank of 91 clear and it will run better without having to modify the tune?
Sent from my Pixel 3 XL using Tapatalk
BIGDJE
OC, CALI
correct thats what @wgr73 is saying its a 37 gallon tank run it down to 30 miles left to empty run 3 gallons of E85 then fill it up with 91 truck will thank you
TYRCS
Thanks for the heads up, just curious where did you get the upgraded fuel pumps and line kit installed to run the ethanol tune? Do you know any shops in O.C that offers this upgrade?
Thanks for the heads up, just curious where did you get the upgraded fuel pumps and line kit installed to run the ethanol e50 tune? Do you know any shops in O.C that offers this upgrade?
BIGDJE
OC, CALI
You don't need any of that for e50 only to run straight e85 stock pump and lines is fine thats what i still have been running e50 since feb no issues
ljn21
Tega Cay, SC
Got the Goosetune and TCM tune, havent had a chance to datalog yet so just on initial tune sent and can say already its way better than my previous tune from Unleashed. Lookikg forward to seeing what the revisions do after I can do the data logs and send back to WGR.
BIGDJE
OC, CALI
No tuner or tune is better then goosetune you will love it highly suggest e50 tune
