GEN 2 COBB Accessport - Tuned by GooseTuned
thatJeepguy
GA
Odd question but does anyone know if there is a way to look at if the injectors are in port injection or Di mode via the @COBB Tuning access port?
COBB Tuning
Austin, TX
There is a monitor on the Accessport called "DFI/PFI Split Actual" that will report a value between 0 and 100 - 0 indicates all fueling delivered through DI, 100 indicates all fueling delivered through PI. Under most driving conditions you'll see a blend of both being used.
thatJeepguy
GA
Amazing , thank you! Is it possible for tuners to initiate port injection only for temporary valve cleaning purposes ? As in run a full tank on port injection every 3 months so the valves stay free of crispies .
TwizzleStix
Commivirginia
If you monitor the split you’ll see that it’s running on port injectors most of the time anyway. The DI rolls in under heavy load to help cool the intake charge for best power at high load. There’s no reason to change unless you have bigger port injectors, etc.
thatJeepguy
GA
Right on ! Good to know thanks for the scoop!
