GEN 2 COBB Accessport - Tuned by GooseTuned
melcam23
I don’t think so. It is a new feature on the 2019s. In the menu it is called measurements. Some of the values possible are oil pressure, oil temp, trans temp, boost and so on.
It’s not a new feature. My ‘18 has it. It’s also on the ‘17 Raptor.
Raptor911
Ashburn, VA
Again, in the gauge cluster, there is a new item in the menu called "Measurements" on 2019s only. It list several engine data points/or values (9 total). Essentially it shows engine parameters in real time when driving. Select any 2 and you can create a digital gauge. See below where I have Engine oil temp and Engine oil pressure set up in my truck.
Not sure why my images are not showing up in publish but do show in Edit mode. You can see the images here: http://eatpho.com/2019_Raptor/Gauge1.jpg, http://eatpho.com/2019_Raptor/Gauge2.jpg, http://eatpho.com/2019_Raptor/Gauge3.jpg and http://eatpho.com/2019_Raptor/Gauge4.jpg
Raptor911
Ashburn, VA
I am not saying that the oem gauges are better. I am just saying for 2019, Ford has provided some more insight into some much needed engine parameters. NOW if Cobb or any tuner wants to take it to the next step, they should push their display/data to the Sync screen. Now that would be a nice feature.
THe gauges that the Accessport has is are way more in-depth, there has to be like 50 options and can set 6. Here is a shot of it
