GEN 2 COBB Accessport - Tuned by GooseTuned
RedPanda
Scottsdale, AZ
You’re right. That’s what im looking for help how to do. One code has no description, one has vin, tire size, etc description and the other is about body control module.
I tried to get to the root of the issue by correcting tire size but that didn’t seem to do the trick.
Apologies if this is the wrong place to post for this.
So, the stock tire size setting is 33.4, not 34.4. Shoutout to Winfield for the fix, worked perfectly. All is well now.
Also, the previous owner was not running the Goosetune TCM tune, but I reinstalled it today with the ECM and it's much better IMO.
smgilles
I was doing it monthly and made sure to get e85 at the same station. I got tired of the mixing and put the XDI HPFP on and it’s much nicer not having to mix anymore and I get e85 wherever.
K223
Florida
So I imagine the E-50 tune is pickier and I having the same given mixture as just running E-85 and it being of lower grade out of the pump? Meaning the tune can deal with it?
smgilles
Yep. @GooseTuned can chime in, but I believe the E85 Map can tolerate as low as e60, since a winter blend of E85 may be lower.
GooseTuned
GooseTuned
New Mexico
Sorry guys I was away for the last week!
There is some wiggle room as smgilles said. ~E60-E85
