GEN 2 COBB Accessport - Tuned by GooseTuned
F100Raptor
Phoenix
No comparison Garrett vs CVF. Have both coolers. Will be using Garrett no doubt
Few other tricks up sleeve too. Can’t wait for first test drive.
moog5050
The EVO HPFP is $1599, that and tuning is about all you need!! If you want to do bigger turbos you'll need the bigger 65% over HPFP which is $2499
I was thinking about this or maybe just the e50 without the pump. But if the pump is changed, can you still revert back to 93 tune. My concern is if I travel to an area where e85 is not readily available.
10SpdsOfFury
Jacksonville FL
You can switch back. The issue is E85 takes a lot more flow so the new pump will accommodate that flow but does 93 with no issue. When you run 93 with the higher flow pump it’s like bringing a tank to a gun fight.
