GEN 2 COBB Accessport - Tuned by GooseTuned
GooseTuned
GooseTuned
New Mexico
You can run E50 (most of the time) without a HPFP. Very very rarely do some trucks have a hard time running e50.
E50 is a blend of E85 + pump 91oct/93oct. You need to know the "e85" content coming out of the tank (use something like this, https://www.fuel-it.com/ethanol-content-tester/) Once you know that then you can blend a certain amount of 91/93 into the e85
TYRCS
How much does it cost to convert onto E85? Kit wise install all the bells and whistles
Install was $200.00
HPFP was $1500
Plus the tune 300 plus ish
And $300.00 to rent the dyno
Chris Mies
Kansas
Hello, Winfield. Would an E30 tune make any sense? I don't have 93 or E85 in my area, but I have E30 straight out of the pump.
smgilles
I ran e30 for a bit before going to e50. It was a very noticeable increase in power/torque over my 91 stage 2 Goose map. Plus you won't have to mix and get fill right off the tap. I would do it in a hot second.
