allinon72
Brand new OEM as I mentoned in my original post.
When was the last time you greased your driveshaft slip yoke? I am afraid to say that my warranty driveshaft is beginning to bind up again. Pull the shaft, and get the specified ptfe motorcraft grease on the splines. Not much oil will leak when you pull it, and grease the shit out of both surfaces.
I’ve had that issue on an older F150 and this isn’t it. This definitely feels like some looseness somewhere in the rear. Doesn’t happen very often because it only shows up when both rear wheels are impacted at the same time. Right now I’m still leaning towards leaf spring bushings.
