clearing the low tire pressure code.
Madcowranch
Genetically Modified
OK
Go on......
Another post on here talked about putting them in a pressurized cylinder & running them
Yep. That was me, too. Doesn't work. I don't know if it's because of the close proximity of the sensors or what.
DynoDynge
Zavalla, TX
Ah, maybe to trigger them they have to be apart from each other?
Maybe someone needs to do a write up on how to unplug the light from behind the dash....LOL
I ordered a new set of tpms sensors for my new wheels & am running 35 psi with no alarm...... Don't know why
E63
Poway, CA.
Yeah, I made a TPMS "BomB", it works for about 20 - 25 minutes of driving then the light comes on. Turns out there is a centrifugal switch in these damn things to save battery life, idk. anyway If I violently shake it for a bit I can clear the error, once off road, with the bouncing around it is happy.
I use the "Orange" aftermarket kit that I now have mounted next to my nav unit. It shows the pressure for each tire, temp too and I can set the min and max warnings.
Hard to argue with the black tape over the error light method...
MTF
Celebration, Florida
With stock tires!
The low pressure light wil come on when a tire goes below 36 psi.
To turn the low pressure light off, the tires (or tire) need to be above 40 psi, and can take up to 20 minutes of drive time to turn off.
Once the light is off you can air down to close to 36 psi. if you want a softer ride like I do.
