Loufish
MAP (Manifold Absolute Pressure) sensors work differently from MAF (Mass Air Flow) sensors....any turbo/supercharged engine needs to know the manifold pressure, hence the MAP sensor.
The intake system would have a IAT (Inlet Air Temperature) to help with the ECU deciding air/fuel and timing, along with the MAF measuring how much air is going into the system (along with RPM and throttle position)...again completely different sensors..
The MAP isn't really prone to a debris issue like the MAF is, however the MAF has a fine wire element that doesn't like dust/dirt and really doesn't like an oil film building up on the wire (from oily air filters)..but the MAF doesn't usually act up with only a few thousand miles...
Hope that helped...
Hope that helped...
