At my friends shop.Did you change the oil in your driveway or somewhere else?
Yes Canadian. I am in Toronto.Check the level ASAP.
Oil leak could be from the trough that sits on the cross member. Or perhaps come oil got onto the skid plate.
Check the drain plug and oil filter for leaks.
Great to see all the Canadian content in this thread.
I have been reading on the forum just now, what is this Fumoto valve being talked about?Check the level ASAP.
Thanks, Where do you guys buy them. What one are you guys all using.The Fumoto is a valve that replaces the oil pan plug. You can attach a hose to it and drain the oil direct;y into whatever container you want just by opening the valve. No mess, no fuss. It’s a beautiful thing, but not necessary. My guess is that the CEL has nothing to do with the oil change.
