GEN 1 Changing shocks what else to do along with it.
poofyo101
I just got my shocks rebuilt and will replace the current ones. It has some of the famous front end clunking. Drives straight and true.
What are some other things that I should replace while replacing the shocks (want to replace necessary parts and get rid of the clunking)
Thanks for the help
CoronaRaptor
CANADA
Just check your upper control arms and lower control arms for play, ball joints, etc. If you've never had a problem with your iwe's, then you're probably good to go. Get the specs for the shock bolts, ex: 406 ft/lbs bottom front bolt, etc.
SS308
Cheyenne, Wyoming
Good time to replace coils (Geisers or Icon), rear leaf springs and add rear shock guards.
P
poofyo101
Ok so
Shocks
Front sway bar end links
Integrated wheel ends
checkUCA
check LCA
check ball joints
anything else?
What is the most common cause for the clunking at low speeds.
IT drives perfect on the interstate
