Raptizzle, or Mr Tizzle/Mr Tizz my shizzle? sir, I have the Deavers +2, RPG 2.5 Bumps, RPG 1.5 UCA RPG Tie Rods and Fox 3.0 IBP & Fox 3.0 Coil overs all in bound.
I also ordered the new RPG LCA and will run the dual shocks up front.
As you know the new LCA is prob 6 weeks out.
If I have everything else installed next week, will it be an ordeal to install the new LCA and addition shock up front? Question is do I wait and do it all at the same time?
R
I'd hold out on the front end til your LCAs arrive. That way you don't pay for two alignments. The first batch of Lower Arms are being assembled now so if you're in that batch, it should be sooner than the six weeks.
Another 2400 plus upper mounts right?
Like Pat said, the upper mounts come with the Lower Arms
The upper mounts come with the LCA's so you would only need to buy another set of rear shocks
What's cool about the external bypass 3.0 is they are specially designed by RPG through Fox and it's not a shock that can be bought off the shelf. From travel to bypass tube placement, they are completely custom. RPG has this dual setup completely dialed.
Real tight
Keep it tight, keep it right.
