Can I get alittle help with motion X on ipad?
Rookie
Fort Wayne, IN
On a 16gb iPad I could only get to 17 and that was pushing it. ended up canceling the download today because it wasn't working for some reason. Might try and switch my data plan to run wifi tethering from my phone
OrangeAddict
Raleigh, NC
Hmmm I would try the iTunes method then. If you go into the help on the motionX gps HD. There is a section on importing .gpx files.
Rookie
Fort Wayne, IN
Download the file to your computer.
Open iTunes with iPad connected.
Let it do it's thing.
Click on the iPad and click on the Apps tab.
Towards the bottom it'll say file sharing and you can see motionx in the list. It'll probably be the only app.
Click on it and you then you can click import or add or something of that nature.
Go find the file and click ok.
Let it add and you should be good to go.
Check by going to motionx, click menu, then click tracks. There should be 5. All you gotta do is click on the one you need and hit start follow
