Can’t figure it out
mtnghost
california
Have you tried a leak down test, also maybe some sort of carbon cleaning. Fist do the leak down and see how much leakage and where it’s going. It will be in one of three places. Exhaust you would hear the air escape the tailpipe. Intake, you would hear it in the intake plenum or tube going to the air filter. Or three in the crank case. For that one pull the engine oil dipstick and look carefully for smoke coming from the tube. This is usually an indication for a bad or gummed up ring. The others are more likely valves and I have seen camshafts in some engines crack and have the same effect. Hope this at least gives you some direction in where to go next. Lastly have a block test done to check for a blown head gasket. Good luck.
MadZeus Darknature
Florida
I had a similar issue with a jeep never do auto zone again . Did you properly use dielectric grease ? And the way it was intended? The error codes can be misleading sometimes and send you down a wrong road . I would start the basic trouble shooting from the beginning of our known gremlins. Message me it’s a little long if you want. Don’t get me started or the ford techs or service centers .
Bsbuggs
OK, I will go to the dealer and buy them. Hopefully that solved my problem.
My Ford Part guy advised me to go on eBay and buy them there at a SIGNIFICANT discount. They are sold with the ford embossing burned off but they are factory coils.. I want to say I save 500.
Highwayman
YUCAIPA
My guess would be as said a little earlier its mechanical IE valve spring.
BUT before you spend on OEM coils, why not just bolt up an old "good" coil and see if it goes away? You know 7 of the ones you pulled were fine, right?
mtnghost
california
Yes, ngk makes the stock coils for ford and they are about $70 each on rock auto. Don’t cheap out on the wires though, the FOMOCO ones come with the proper clips to retain the wires where they belong. I transferred my clips but some also broke.
