Camping Weights on bed vs suspension
MarkG
SoCal805
The only thing unusual I had to do was for the front kb brackets, the usual way to clamp them in is to have the nut on the inside of the bed. I reversed this so the head of the bolt is on the inside of the bed and the nut is on the outside under the bed rail. This way the tonneau cover container can fit between the kb brackets.
The kb brackets would prevent the forward two pace Edwards brackets from sliding all the way forward but they are 80% of the way and that should be more than enough to hold the tonneau cover down.
Let me know if that made sense. If not, i’ll get some pictures for you.
I’m going to give it a shot, thanks for the info.
Sheeepdog18
Sheeepdog18
Bay Area
Just finished my custom bed rack and install it on my bed to test fit. It worked out perfectly. Next is to powder coat the same color as my truck but with a satin finish leaving the diamond plate polished.
