Cam Phaser/Engine Failure Reports
Status
Not open for further replies.
GLT
DFW
It's been mixed. My dealer claimed it's normal operation. I've hired an attorney and have endless videos time stamped of the rattle and knock. My noise is definitely changing as I have a start up rattle for 2-3 seconds, then what sounds like change or bolts being shaken in a metal coffee can for the first minute or so (this has progressively gotten worse), and then turns into a knock from the passenger side of the truck.
What you're describing is exactly what my wife's 2018 Expedition is doing. Amazingly, I haven't had any issues with my '17 Raptor, so far (knocks on wood...). Both have right at 23K miles.
MagnetMan14
2017, Feb build, 34,5xx miles. Just talked to the service contact at dealer. Replacing all four phasers and camshafts(???). Asked, no chain ordered.
18BlueScrew
Virginia
Wanted to report in that I may be joining the club experiencing the rattle, with my 2018 SCREW manufactured 9/17 it occurs not only at startup but under conditions identical to TSB 18-2354. I'll be heading into the dealer this Thursday for diagnosis. Here is what mine sounds like.
MagnetMan14
Is it worse at cold startup?
Crash45
This is correct I’ll post them tomorrow too
Dropping mine off Thursday. Sure would like a parts list...
Also, mine hasn’t rattled in awhile, but idles really ruff sometimes now at lights. Doesn’t seem to affect performance, but I can feel it in my seat...
TigerRaptor
Baton Rouge, LA
Dropping mine of Thursday. Sure would like a parts list...
Same here Crash with the rough idle. These are the parts I am having replaced that Ford approved:
4 VCT solenoids
2 intake phasers
2 Exhaust phasers
1 primary timing chain
2 secondary timing chains
1 primary timing chain tensioner
1 left primary chain arm
1 right primary chain arm
1 left chain guide
1 right primary chain guide
2 secondary timing chain tensioner
2 secondary tensioner shoes
2 intake cam bolts
2 exhaust cam bolts
RMB_Ryan
Wayne, NJ
4 VCT solenoids
2 intake phasers
2 Exhaust phasers
1 left chain guide
2 intake cam bolts
2 exhaust cam bolts
So do you have a gen1?
If not that list is for gen1. These have 2 primary chains no secondary (if no one else mentioned this)
Status
