Super clear and helpful, thanks!The 3.5 EcoBoost is not an FFV. If you wanted to run E85, you would need an aftermarket calibration. The fuel system may also require upgrades due to the high ethanol content.
... Notably those "improved components" seem to be higher flow/capacity pumps that I can infer are just to get more fuel to the engine since a ~200hp gain is going to use a lot more fuel (that's the HP gain claim)...
I totally forgot about the density differences: https://afdc.energy.gov/fuels/fuel_comparison_chart.pdfOnly partly. Ethanol has a much lower energy density than gasoline so you have to deliver a lot more of it to get the same power. More power? A whole lot more, hence the new fuel pump and injectors.
