Maybe I'm too ****, and an avid SCUBA Diver, but I'd turn that tank around. If by small chance that tank regulator blows off....you have a missle headed towards you. Just say'n.
I believe you will have to unmount it to use it as using it horizontal will mean liquid CO2 will come out instead of gas.
As long as it's vertical when you use it, it will be fine? So mounting it horizontal, but using it vertical is good?
I hear what you are saying. I did it that way because the latches would be on top instead of the bottom. But perhaps the inconvenience over safety is worth it. But if this is unsafe regardless what way its pointing, do I really want to do this anyways? Are you saying that it looks unsafe to you?
