WhatExit?
I'll also add that (in my case at least ) it should be noted that my center light location doesn't allow for the light to rotate up enough to point straight (light hits the bumper on the bottom) this is why I use this location for fogs.... works perfectly for my application.
So you're saying the 2 Baja Design lights cannot be angled upwards enough to give you the down-range aim that you want? Does Baja Designs know this about their kit/brackets? (I don't want to have that issue when I buy them).
Here's your pic:
![K9wAup0.jpg K9wAup0.jpg](https://www.fordraptorforum.com/data/attachments/262/262928-89bcd2318ab9b72d5667b038c4b4eae4.jpg)
Note: I clicked on your pic at the IMGUR web page URL you posted to make it full size then copied the Image Address of that large pic. It needs to have a .jpg or .png file type at the end to be able to use it
---------- Post added at 01:32 PM ---------- Previous post was at 01:25 PM ----------
I bought my lights right as they came out and absolutely love them. BD lights are (in my opinion) the best on the market. My setup is a little different than most since I ordered my lights right as the kits were being finalized. I have 1 set of Squadron Pro wide cornering on the inside, 1 set of Squadron Pro spots in the middle and 1 set of S2 Pros (with amber rock guards) on the outside. I bought mine from @Rick@FreedomMotorsports. He was great to work with and got me a great deal. He was even able to work directly with BD ensure that I got the lights I was looking for.
You can see my setup here:
http://www.fordraptorforum.com/f263/baja-designs-fog-light-install-53532/#post1123253
Thanks for posting the link to your install - it's helpful as I don't remember seeing it before.
Do you have any problem with adjusting the angle of your Squadron Pro lights up or down as Smokeshow60 mentioned in his post? (If not maybe his brackets are different or he installed them differently?)
Here's your install from your thread:
![Nk2uUn6h.jpg Nk2uUn6h.jpg](https://www.fordraptorforum.com/data/attachments/262/262929-f22da44c3bd7728654826ac3e178c474.jpg)
