SeXualAVENGER
I changed my oil today, which was my third oil change. I only got a little over 5 quarts when draining the oil. The first two times I got much closer to the 7 quarts that it requires. I changed the oil at 1000 miles, 4500 miles, and 8000 miles. I used royal purple 5w20 w/ a royal purple oil filter each time. I have not noticed anything out of sorts w/ the truck, and there have been no leaks. I probably should have checked the oil level prior to changing the oil, but I didn't. The only thing I can think of is maybe I burned up some oil during the snoball 500 when pushing the truck a bit. Is this normal, or should I be concerned?
