KaiserM715
Kaiser Söze
@treypal - any additions / revisions?Common wrench sizes on the Raptor that I carry. And other tools
10mm
15mm
18mm
21mm
27mm
29 or 30mm socked (lower shock bolt, probably overkill).
A small 3/8" drive socket set (the kobalt set with the pass through wrenches is good because it sort of acts like a deep socket and shallow socket set in one)
4 lb hammer
Small and Large Crescent
Small and Large Vice Grips
Lineman pliers
Channel locks
needle nose pliers
18" aluminum pipe wrench
screwdrivers (don't cheap out here)
Spare parts I carry.
IWE
Power Steering Pump
Wheel Speed Sensor
U joints
Fluids I carry
4 qts 5w20
2 qts ATF
1 qt gear lube 75-140 I think
half gal of ford antifreeze (gold or something like that).
Misc.
Zip Ties
Gorilla Tape
Shop Rags
Vacuum tubing
hose clamps
Ratchet straps
Bungee cords
Tire plug kit
Valair Compressor (its not as fast as CO2 but takes up way less room)
Silicone self fusing tape
Electrical tape
Recovery
Bubba rope with shackles
20' strap without as much give for flat towing
Hi Lift Handle All set (shovel, axe, sledge, etc,,,). I usually only carry the shovel and the sledge.
HF Floor jack on skid
Survival/first aid
Power Bars
Sunscreen/Bug Spray
Steripen
Epipen
Stop Clot
Sutures
Standard first aid kit
Packable wide brim hats
Survival blanket
When I think of more I'll add it. I can get most of this stuff into the truck along with a second spare, a yeti cooler, my wife, two dogs, camping gear etc...
