Brake Upgrade
Chris@FreedomMotorsports
FRF Gofur
Woodlawn, Virginia
A little more for everyone so that they understand why some have said not to use DOT 5 fluid.
If you want to look at brake fluids from a chemical standpoint DOT 3 fluids are based on glycol and glycol esters. DOT 4 fluids are much like DOT 3 fluids, but also contain borate esters. There is another rating called DOT 5.1 that consists of borate esters.
Notice that water is not listed as a component of brake fluid. Water boils (sea level air pressure) at 212 degrees F (100 C). Since the disk rotor can and will generate over 1000 degrees (F) of heat and transfer 400 degrees or more to the caliper water is not a good fluid to choose.
Why do I mention water? The chemistry of DOT3 and DOT 4 brake fluids attract water. Right out of the air. In fact the anti-freeze you use is probably glycol based just because it mixes well with water.
The difference between the DOT (Department of Transportaion) ratings of brake fluid are the boiling point ranges that they achieve both dry (no water absorbed) and wet (about 3-4% water content). For DOT 3 the dry boiling point is at least 401 and the wet 284 degrees. DOT 4 raises the bar to 446 and 311 respectively. Those are the DOT ratings mind you , and there are high performance brake fluids that exceed those ratings.
The cost of brake fluid can vary as well from less than $0.20 an ounce to over $2.00 an ounce. Some of the high performance fluids are rated well over 500 (to almost 600) degrees boiling point dry. Wet boiling points will also vary, but be well over 400 degrees.
The higher boiling points are critical to those of you that wish to spend time on a race track. Once you boil your brake fluid it will not recover and you MUST bleed and change out the fluid.
The every day driver will find brake performance just fine by sticking with the fluid that the dealership recommends unless they use their vehicle to the extreme, such as a newspaper delivery route or negotiating their way down curvy mountain roads. You will know because the brake pedal will start to feel mushy as the fluid overheats and the pedal may even go to the floor.
So what is the big deal? The big deal is that most of us never flush and replace our brake fluid. In fact, if you go to a garage and have a “brake job” done it is highly unlikely that they will do much more than bleed the brake lines. This means that the old – water soaked – tired – brake fluid will still be there. The water can react to oxidize brake components from the inside out. What you should do, probably once a year, is have the old fluid flushed and completely replaced with fresh brake fluid.
Now, which one is best??? You should do your own research, but I have seen many comparisons in researching which brand to recommend. While I sell AMSOIL and they do offer a great product, I have found that there are several brands out there that offer products with higher boiling points. Since the boiling point of the brake fluid is going to be the main standard by which to judge them, that is what I look at when I was looking for a product to recommend. AMSOIL DOT 4 performance racing brake fluid has a dry boiling point of 580* dry and 410* wet. The DOT minimums for DOT 4 are 446* and 311*. About the only other brake fluid that I have found that has a higher overall boiling point than most others happens to be the Wilwood EXP600 DOT 4 Fluid with a dry boiling point @ 626* dry and 417* wet. However, it is NOT CHEAP. a 16.5 ounce bottle will cost you $20 or so before shipping or sales tax and you will need at least 2-3 bottles on hand to ensure a proper full flush.
Hope this helps everyone with knowing a little more about their brake fluid. But like stated, DO NOT USE DOT 5 or 5.1 in your truck.
cups
Fair Oaks, CA U.S.S.A.
cl & turbo, you touched on this. Are there any component comparability concerns, with other than Ford recommended fluid, corrosiveness or performance, i.e., ABS? Let's just talk of DOT 3 & 4.
FRF Gofur
Woodlawn, Virginia
In short, no, there shouldn't be. In my experience there is nothing about the fluid brand differences that I know of that really make a difference when replacing Ford Motocraft fluids with another brand fluid. The main thing you would be doing is installing an upgraded option for the fluid. Nothing more. The hard parts, brake master cylinder, calipers, lines, etc are not specifically designed for the specific fluid, Motocraft brake fluid formulation is similar to the others in that it uses the same base components in the formulation of the fluid.
Chayse
SE PA
Does anyone have the Ford recommended brake bleeding sequence? if you are going to swap out fluid, it is a good idea to flush all of the old stuff. not because of incompatibility (if using DOT3 or 4 fluid), but because as stated above, Brake fluid absorbs water. if going to a higher quality fluid, make sure to bleed all of the old stuff out to get the full benefit especially since at the calipers is where you want the new, better, fluid to be anyway. A lot of car guys will go with the super blue ATE and Typ 200 combo. Switch to the blue and during bleeding, when the color changes to blue, you know all the old fluid is out. then at the next change use the TYP 200 (exact same fluid but amber) and when the color changes again, you know you are good. I have not seen it, but some say that the blue fluid can stain the reservoir, not sure if that is true or not. and Florida has a law that says you can't have blue fluid for brakes in FL
Hockster
My 45ft Bluewater Party
Winchester, Va
^^^In order to use the Ford recommended procedure you need a scan tool to cycle the ABS unit... You can did this yourself by driving and using the brake to activate the ABS. Takes a long time this way but it does work...
FRF Gofur
Woodlawn, Virginia
That blue fluid DOES stain. I have seen it in person. Never used it, but I have seen a master cylinder that had it in it and it does stain it pretty good...
J DAMAGE
NJ
Do NOT use dot5 fluid in your raptor.
Dot5 brake fluid is not hydroscopic and is not compatible with dot 3 or dot 4 fluid. Dot 5 is also not recommended for abs systems. Please be careful in in your recommendation. People might just follow that and cause damage or worst, get in an accident.
TURBO95MAX IS 110% CORRECT, was not thinking and drew a total blank on the ABS system, so thank you for pointing it out, correcting my incorrect recommendation, and also saving me in my lack of thinking it out and
using it
Forgot that the pulsing of the ABS will AERATE a silcon base. Again thank you.
Turbo95max
San Bruno, South SF, Petaluma
Any good dot 3 or dot 4 will work fine. I always use dot 4 in any of my vehicles. Been tracking my rx7 for years without any brake fade. The important thing is to change your brake fluid regularly. We recommend once a year or before track events. And yes ate super blue will stain the plastic reservoir over time.
mrmojoz
Arlington, TX
Sometimes I feel like I won't stop in time. Living in the city there are too many red lights....do you guys experience the same with this heavy ass truck or am I just braking late?
There are three good ways to make a vehicle stop in a shorter amount of space:
1. Reduce the vehicles weight.
2. Reduce the vehicles speed.
3. Increase the amount of grip the tires have (compound+surface area).
Pads, fluid, steel lines, big calipers and rotor upgrades are good for reducing fade and adding more bite. They don't stop the truck after all, the brakes job is to stop the wheels.
FRF Gofur
Woodlawn, Virginia
Your assessment is incomplete.
If you stop the wheels, you stop the vehicle. I have never had a problem at all with installing good hard brake parts and fluids and the vehicle didn't stop. I have tested stopping distance improvements before and after installation of better products and they have improved greatly in many cases, especially in my Duramax and Denali.
