there is a sport mod,u never try it?
and :
Most of us have either seen or heard of the new 10-speed transmission Ford is offing behind the 2.3L EcoBoost, 2.7L V6, 3.5L EcoBoost, 5.0L gas, and 3.0L Power Stroke Diesel engines. It’s been on the road for a few years, and we’re starting to see some common failures for this unit. Before we get
gearsmagazine.com
While working on a 2017-2018 Ford F150/Raptor, 2018 Expedition, Mustang, and Lincoln Navigator equipped with a 10R80 transmission, you may experience erratic TCC operation, or a TCC shudder concern. Codes P0741 or P1744 may or may not set in the PCM or TCM (depending on application).
Since its creation, Ford-GM has integrated the 10R80 transmission into many of its new models successfully.
www.hotcars.com
Ford’s 10-speed automatic transmission has been on the market for a few years, and customer complaints have been pouring in since day one. So, has Ford finally corrected the 10-speed transmission? They’re working on it, in a nutshell.
According to the Motor City Mustang manufacturer, most customer complaints are due to the adaptive learning software in the 10-speed transmission. In layman’s terms, Ford refers to a process in which the transmission “learns” your driving behaviors to increase fuel economy and ride comfort. A difficulty arises if the system is reset for whatever reason, and you must learn your habits repeatedly, resulting in jerky shifting for a brief period of time.
Ford’s first attempt to address the 10R80 issue was in 2018 when they issued a technical service bulletin. A TSB is a manufacturer’s internal letter provided to dealerships as the official method for problems not yet addressed in the handbook.
According to this service bulletin, customers who are having trouble with their Ford 10 speed transmission should reprogram the control module. Although the update appears to have resolved many consumer problems, some remain unsatisfied.
Ford has also supplied some other adjustments for the 10 speed, including an
improved shift cable clip and, in some cases, the replacement of the first gearbox. The good news is that it appears that Ford is now paying attention to the problems and is actively working to resolve them.
