You have a link to the adapter?
Everything I see just didn't seem right.
http://www.boombaracing.com/2017-ford-f-150-raptor-3-5-ecoboost-blow-off-valve-adapter-bov/
but u still touching cables from the sensor and the clips don’t get attached good enough causing check engine to light up. I was looking into that and boomba was the best option. 65 bucks and no messing with the sensor whatsoever. The loose plug was my faulti would suggest buying the turbosmart BOV. Sensor is no longer used and it comes with clip that attaches to sensors wire leads to fool the sensor
That’s what I had before. The difference is that boomba gets attached directly and you don’t have to disconnect anything. Better sound (way better!!!) even with the low rpm’s. The plug is just a plug. U can’t even compareHow does this differ to this?
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/112675072891
