Billet Oil Pump Gear Group Buy ???
MTF
Celebration, Florida
Got # 6
And just to be on the safe side I also got the upgrade fuel pump.
Maybe someday I'll go to a 590+ rwhp setup and I will be covered.
MTF
I purchased the pump from Livernois.
Part No.: F90000267
Make: TI Automotive Universal
Fuel: FLEX
Horsepower: 750+
Flow Rate: 450 LPH
I've been on the fence about buying it, especially after seeing what Biggest did.
I've been told by Whipple and Livernois and others, I wouldn't need a fuel pump upgrade at the power levels I'm at.
But JDM ran into a lean condition because of fuel starvation when they Tuned a Whippled Raptor up to 591 rwhp and had to dial it back to 550 rwhp.
And they are getting the same pump, only time will tell if it solved the problem. If I hear more about what JDM did I'll have them update that build.
Biggest
Part No.: F90000267
Fuel: FLEX
Horsepower: 750+
Flow Rate: 450 LPH
Why are you guessing? I'm running ID1000 injectors. That's 100 lbs I'm pushing 18 lbs of boost. The BAP works! It can be wired to only kick in when needed. Under 5 lbs of boost it does not come on. We all spend time on the internet, I make my decisions after I do my research, bell had sold 17000 BAP and there has been 1 documented failure due to improper wiring.
If I want a TT I'd go to the best.
When I read anything to do with Ford performance the names I see every time is , Lethal, Lund, Kenne Bell, L&M Engines and Evolution.
MTF
Oh, I agree with you 100%.
You have proven that the fuel pump is not needed if you use the BAP unit.
Still there are some on the internet that say both are needed at power levels that are above 1000 HP.
And then the whole fuel line needs to be upgraded as well.
I'm certainty never going to be there, but your pretty close. :)
Fuelonempty
So the billet oil pump is all that is needed for the upgrade? I have heard of trucks loosing their engines due to these things, wondering if this is all you will need for an otherwise stock internal motor?
Thanks
MTF
No comment from me, way to early to to make any predictions. IMHO
Only one gear set is up and running but on a built motor.
Mine was supposed to go in tomorrow to get them install.
I hope I can get my truck in sometime this week.
GoMuscles
Houston
Good luck buddy.
Mine is still siting in the box...
metronyc
New York City
Just receive my oil pump gears from Livernois made by TSS 6.2 6A-05 . now start planing the installation .
